histogram from image results in a straight vertical line
I've only just started using simulink and I've got a bit of a problem where i take an image (color), convert it to an intensity image and try to make a histogram of this image.
the first two parts work but for some reason the histogram block always gives me a straight vertical line. the output of the RGB to intensity is also confusing me a little as its the correct gray image, but if i use a display block every entry is a 255.
sorry for the noob question
danny
