Measuring thrust (and NOT torque) of rotating shaft with strain gauges
I'm trying to determine a strain gauge configuration that will allow me to measure axial strain (thrust, in tension) of a rotating element. Shaft, or coupling spacer.
I want to cancel out the torque loading which will be significant.
It seems that a Full bridge type III with 4 strain gauges would work. Two of them 90* on opposite sides of the shaft to measure axial strain, and the other two at 45* to cancel torsion.
I've seen the application as described, except 0* orientation to cancel bending... Which is negligible in this loading scenario. Please see link, last item on the page.
http://zone.ni.com/devzone/cda/tut/p/id/4172
Will this arrangement reject strain due to torque if using a 45* orientation?
Additional information:
1) As you can see at the bottom of that page, someone (not me) asked a few months ago if the 0* arrangement would cancel torsion, I assume that it will not.
2) It is not an option to measure anything related to a bearing, or mounting flange, this would be too intrusive. The measurement must be derived from strain gauges on the rotating shaft. (This is why I asked in the instrumentation forum and not in a mechanical forum!) I have done some research, closest I came to similar application was measuring thrust AND torque on propellers for boats, but I want to remove the torque so this was not 100% applicable. Same with automotive components, they are concerned with material stress of the combined loading, I am not.
3) Plan to use a very small data logger that will rotate with the shaft. I mention this, because obviously getting the readings from strain gauges on a rotating element would be a little tricky and I want to avoid the response of "doesn't matter because you won't be able to wire it up." :)
4) Thanks in advance for any guidance.
RE: Measuring thrust (and NOT torque) of rotating shaft with strain gauges
If all gages are positioned perfectly then the bridge will only be sensitive to axial tension/compression. Misalignment of the gages may make them sensitive to torque.
If the axial strains are small relative to the torsional strains then it may be tough to make the transducer insensitive to torsional strains.
Most cases, axial thrust value(lbs) will be around 2-4x torque value(ft-lbs)
It's not so much the lbs and ft-lbs that is important. It's the strain due to each that is important since that is what the gages respond to.
Have you looked at Vishay - MicroMeasurements web page? It's been awhile since I have but they used to have quite a bit of info on gaging.
I'm new to the forum so sorry if this has already been said or is teaching you to suck eggs, but you may have issue with the logger on the shaft depending on the RPM i.e. G Load you you be subjecting it to?
It may be an option to look at a telemetry system or a slipring to bring the signals off the shaft and record / process them locally? It might be worth googling "Datatel Telemetry" or looking at one of the miriad of slipring suppliers to make the acquisition simpler and enable you to monitor it real time?
Hope this is useful
Matt.
Gunnar Englund
www.gke.org
Good point, I didnt read the OP with enough detail, however I think my point may still stand, I have never managed to find a data logger that is small enough not to affect the rotor dynamics on a small shaft & has a high enough sample rate to be really useful.
Sorry to hijack the thread but if you know of one I would be interested!
Matt.
Dimensions: 42 H x 68 W x 20 mm D (1.7 x 2.7 x 0.8")
Weight: 60 g (2 oz)
Reading Rate: 20 Hz to 12 hours
All solid state, so I can't imagine any issues with loads from rotation.
It will work for some applications I have in mind, installed inside a rigid coupling spacer (which transmits torque and thrust.) More difficult to set up on a small shaft OD, I agree.
Appreciate your responses.
Don't under-estimate the long term effects of high speed rotation. We used a rotating earth fault detetctor on the shaft of our generators. The unit was solid state and rotating at 3000 rpm. They had an indifferent survival rate, considering the cost of them they had a fairly poor rate to be honest. I know they didn't contain any electrolytic capacitors, which are the most vulnerable to rotational damage, but we always suspected that the bond wires of the semiconductors were the next most vulnerable component. The whole things wa spotted in resin which we always failed to remove without destroying the circuit in the process.
This would be for short duration testing, intermittent use, non critical application. Max 3600 rpm, more often 1800/1200. So if I go this route I'm pretty optimistic.
Unless yours used surface mount components as well, then all I can say is that I plan to place it in the middle of the rotating coupling, so velocities will be lower than mounting to the OD of a shaft for example.
Can hold it in place with foam so there is minimal shock from vibration.
