How to Calculate Wind Load on a Rectangular Antenna
3
I need to calculate the wind-loading force (lbf or N) that will be applied to my rectangular antenna enclosure (face area of 2.6 sq ft /0.24 sq m) in a wind speed of 60mph (97km/h. The estimated drag coefficient (based on a flat face with rounded edges) is 1.9.
Can someone provide me with the correct formula to use, or point me I the direction to solving this?
Thank you,
Solsurfer1
RE: How to Calculate Wind Load on a Rectangular Antenna
Check a fluids book or wikepedia.  I think the eqn is F = 0.5 * Cd * rho * v^2 * A  (maybe throw in a 1/g for correct units).  Rho is air denisty, 0.075 lbs/ft^3 should be close enough. Other symbols should be obvious.
SolSurfer:
Fluid mechanics and wind tunnels is one approach.  Structural engineers look to ANSI/ASCE 7- latest ed., for wind loads on structures, and it's a real mind bender, but it is the building code for these kinds of things.
I agree with dhengr...
ASCE 7-latest edition should walk you through the analytical process to determine an applied force for your structure.  I find non-building structures to be easier to analyze and less "mind bending" as dhengr put it. It does take a little guidance to get through all of the variables though the first few times.
DFLewis
www.phoenix-engineer.com
SolSurfer....Assuming you are in the US, the minimum wind load that should be applied is 90mph.  That's the starting point.  As dheng noted, ASCE 7 is the defining document, as laborious as it might be to check your specific requirement.
i've been discussing the same post over in the aero. forum ... make me think he was putting an antenna on a plane.
anyways, i was wondering if the code defined the wind speed, then the load is 1/2rhoV^2*A, or the pressure, then the load is p*A ...
