Creating Multiple Holes Of The Same Size Within The Same Command
Beginner, Using CATIA V5R18;
I would like to know if you can create multiple holes of the same size within the same command, or does CATIA allow you to create only one hole per command?
Any response will be greatly appreciated!
RE: Creating Multiple Holes Of The Same Size Within The Same Command
Fernando
cadromania.net - Romanian CAD forums
Fernando
In fact. there is nothing I can think of in Catia or Pro-E (which are the only 2 3d programs I know) that actually does much of anything with just one command.
1. Hit the "Hole" feature once
2. Create 2 holes with 2 sketch points
3. 2 holes created under one feature
4. If I look in the part tree, I will see only "Hole.1" & not "Hole.1" & "Hole.2"
This gives the advantage that you can directly dimension the holes to other features just by showing the sketch. If you are used to the pro-e way of doing stuff you will find that this is much cleaner as you can go in and edit one sketch to change placement.
