Network install of cast
Did someone do a successful installation of the cast on a networkdrive?
I can open all the html files, but when I want to open examples nx-parts it give the following location error:
Locating the parts
The CAST Library parts are, by default, located in the directory shown below, which is established during installation:
Linux: $UGII_BASE_DIR/nxcast/parts
Windows: %UGII_BASE_DIR%\nxcast\parts
The parts at your facility may be in a different location, depending on how the CAST Library was installed. If you cannot locate the parts, see your system administrator.
The parts used in the activities in this course are located in the sketch directory.
All parts are read-only. If you want to save a copy of a part, use Save As to save the file to a location where you have write access.
I already tried a few things:
open via batfile: UGS/nx7.5/nxcast/castonly.bat
add system variable:
UGII_CAST = U:\unigraphics\nxcast
UGII_CAST_HTML_DIR = %UGII_CAST_HOME%\html
UGII_CAST_HTML_URL = %UGII_CAST_HOME%\html\index.html
UGII_CAST_PARTS = %UGII_CAST_HOME%\PARTS
Moved the parts to %UGII_BASE_DIR%\nxcast\parts
Installed the cast again, but instead of choosing 'No' at installing as webserver choosing 'yes'
Nothing seems to work.
I hope someone else knows the answer
Thanks in advanced,
Robijn
nx7.5.2 - windows xp 32bit
Locating the parts
Thanks in advanced,
Robijn
RE: Network install of cast
We do not access CAST from within NX and we do not access our example part files from within CAST. We have a session of NX running alongside CAST and access the part files by the normal NX File>Open and then browse to the example part files location and select the file.
When we click on the little icon at the top of the CAST screen, we get the same message that you listed... I believe it's there to tell you HOW to find your example parts, not to open an explorer window listing them.
Maybe this is a by-product of not integrating CAST into NX, tho.
Anyway, that's our method. Seems to work ok.
thanks for your replay. I will use your method.
If you add the following system variable, you will be able to open the cast within NX
UGII_CAST_HTML_URL = your index.html location
Kind regards
