standard liquid flow rate in HYSYS
Hi all,
HYSYS reports two types of "liquid flowrates" in its conditions results tab as follows;
1. std ideal liq vol. flow in barrels/day
2. liq volume flow@std cond.in barrels/day
the values assigned to these two conditions are usually close. but my question is, what is the real difference between them? and when should one pick either of them?
Buchi
RE: standard liquid flow rate in HYSYS
i have found the answer to my question. so you don't need to bother.
Buchi
