IEC 61850 GOOSE messaging among different vendors
thread238-263107: SIEMENS icd file
There was a question on how to send GOOSE messages between different vendors
RE: IEC 61850 GOOSE messaging among different vendors
The software tool of the receiver IED should import the SCD file, read the input section and instruct the IED to receive that GOOSE message (actually to receive the dataset in the input section, and the dataset is described in the GOOSE CONTROL BLOCK of the sender IED in the same SCD file).
If the SW tool of the receiving IED cannot do that, I don't think you can call that IED as "61850 compatible" because it doesn't support engineering at SCL file level.
Maybe not so clear...
