Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The level of expertise is awesome. The nature in which people respond is professional helpful and not the least condescending. I can't say that for most forums..."
Geography
bootnreboot (Aerospace)
15 Nov 10 16:56
does anyone know where the real definition of the ANSI depth symbol is?
if i use the depth symbol  ( the one that has a straight horizontal bar with an arrow pointing down at its midpoint ) where is this depth measured if is defining a drilled hole?
My view would show a hole with a drill point in the bottom of it. The callout could be  .375 DIA X (depth symbol) 1.25
so it would be read as .375 diameter by a depth of 1.25.
where is the 1.25 measured? to the very point of the drill point shown or would it be interpretted as the depth of the .375 diameter and the drill point is not considered?
where is this defined? i do not see anything in the ANSI Y14.5 to define this.
KENAT (Mechanical)
15 Nov 10 17:04
ASME Y14.5M-1994 1.8.9 Round Holes & figure 1-34.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
17 Nov 10 11:57
thank you!  all i could find was the 3.3.14 and fig 3-14 but it was not defined where the depth was measured.
mrainey (Industrial)
17 Nov 10 16:33
In my experience, the full-diameter depth is what's being called for 99% of the time.  Given that the included angle of the drill point can vary (usually either 118 or 135 degrees), it can get dicy if the material left under the drill point is thin.
Software For Metalworking
http://closetolerancesoftware.com
drawoh (Mechanical)
19 Nov 10 18:34
bootnreboot,
   ASME Y14.5M-1994 (fig 1-34) and ASME Y14.5-2009 (fig 1-36) both clearly show that specified diameter extends to the specified depth.  The drill taper extends below that.
               JHG
Close Box
Join Eng-Tips® Today!
Join Us             Close
