How to define elastic-plastic model in abaqus cae?
I want to define a elastic-plastic model, how do I input the properties of the material? First if I define material 1, then do I have to input its elastic properties and then the plastic properties? Is this the procedure?
All comments are welcome.
Thank you.
Thank you.
RE: How to define elastic-plastic model in abaqus cae?
It's the procedure. You must defined elastic (Young's modulus and Poisson's coeficient) and plastic behavior (give the curves stress vs plastic strain).
