Spline Associativity
Why splines which are made in sketch are not associative? If a start or end point of a spline is attached to some line with G2 or G1 constraint, and line is later moved, G1 and G2 constraints are lost. But if a spline is drawn outside sketch then it is associative.
RE: Spline Associativity
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Jerry has given you the current 'best practice' workaround; just be sure to choose the plane you want to draw on in the studio spline command, it annoyingly defaults to the view plane (in NX6 at least).
