Solid Works 'Print All' options
There are many times when an option to print all open drw's in SolidWorks would be very helpfull. I've heard of ways to do this after the file has been saved as a pdf. I am curious as to whether or not there is a way to print all the drw's currently open in a session of Solid Works vs printing one at a time. Any input would be appreciated. Thanks!
-Russ
-Russ
RE: Solid Works 'Print All' options
I know, its not exactly what you were asking for (files that are open), but for me the files I have open are generally in the same folder location
I ran a trial using Task Scheduler and wasn't able to find options for scaling drws to 'scale to fit' which is the default of my SW. That cause printing scales to be wrong. Aside from that it also took more time vs just opening them all and manually printing. I can see this as a usefull tool when in dire need to multi-task. Thank you for your input.
"available on line"
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
Both the utility and batch process are noted on Solid Works website and look like good options. I'll have to check around and see if I can download these through IT.
