Stress vs Strain relation in Patran
I have been trying to find the trivial relation between stress and strain when post processing the results in Patran.
I use the fringe plot with labels at the gauss points, without averaging and with shape function extrapolation.
This gives me labeled values at the four gauss points of my CQUADs. I read the stress tensors values. If I get the x, y and xy component of stress and manually calculate the von mises stress and compare to what Patran gives me at the four gauss points, it matches exactly.
Now, I read the same results for strain tensors but can`t match the stress values with the strain. Basically I would have expected, for linear analysis to read E = stress/strain. But for plain stress, one needs to account for the poisson effect. Even then, the strain tensors I read in Patran is really far from what I calculate.
One difference I am noting is that stress values are given at the two extreme fiber of the thickness of the shell while the strain values are "non-layered". This might give a difference, but the results are really far from each other.
For example, i read a sigma x = 5.69 psi, sigma y = 0.926 psi, xy = -0.874, E = 350000 psi, v =0.42. I calculate a strain of 1.18115E-05 with the following formula : ((1+v)/E)*(sigmax(1-v)-v*sigmay)
Patran gives me 2.49 E-06.
Any idea why and how can the two be related?
Thanks.
So the question that arises is do you know how stress tensors results in Patran are related to strains?
Thanks.
