plastic valves VS lined metallic valves
Good morning,
I need to choose some valves for a neutralization plant involving Hcl Acid(30%, T°30C) pipes and NaOH (30%, T°45°C) pipes. The operating pressure is 6 Bars.
I'd like to know the pros and cons for using plastic valves vs lined metallic valves (linned with PTFE or any other thermoplastic).
In my mind, i think plastic valves are les expensive but the are less rugged than metallic valves. I think also that high temperature (45°C) can affect plastic valves life.
Am i wrong or right? Is there a possibility that plastic valves could be use in such application?
Thank you very much.
Djaz.
Djaz.
RE: plastic valves VS lined metallic valves
I'll check if flanged style plastic valves are rated the ASME Flange class. If not, it can be a serious issue to solve.
In fact, most of the valves i am looking for are manually operated. So, i think there are more manufacturers in this case than it is for control valves.
Iam still open for any suggestion regarding this topic.
Djaz.
The catalogue of georgfisher is really impressive. There are a lot of plastic products for industrial process (what i am looking for actually).
Great!!!
Djaz.
