Applying material texture surfaces on non-metallic hose
How can a texture surfaces like shark skin texture be applied to the surface of a non-metallic flexible hose of approximately 16mm diameter?
RE: Applying material texture surfaces on non-metallic hose
There are drawing symbols for various lay patterns, so you would have to specify both surface texture and lay. If that does not get you the surface you need, then you will have to quantify it in some other way.
