Ordinate Dimensions on angled plan
Greetings,
I have an airfoil, and I need to dimension some points along the length of the airfoil.
Unfortunately due to the orientation of the airfoil with respect to the rest of the model, the line I need to dimension along is neither horizontal or vertical. Is there anyway I can ordinately dimension it?
Yes, I could smart dimension the whole length (:P) but I have quite a few points to dimension and I want it to be relatively readable.
Let me know if there is a work around. Thanks for your help!
RE: Ordinate Dimensions on angled plan
Right click on a toolbar
Customize
Commands
Dimensions/Relations
Drag angular ordinate tool to add to your toolbar
Felix, I tried that again, and I realized I was trying to start the dimensions from a point, which default to either horizontal or vertical ordinate. If I dimension from a line instead of a point, it comes out in the proper direction. Thanks.
