Switch light on/off using a transistor based on input voltage range?
I am a ME with very basic understanding of electronics. I am trying to design a simple circuit for use with one wire alternators to allow you to use the idiot light (indicates the system is not charging correctly).
My concept is that the normal voltage of the system should be between 12.5 and 14.5 volts (or some similar range). Can a transistor be used in conjunction with some resistors and diodes to switch on and off a light that would indicate the system voltage is within or outside the given voltage range?
If this is possible, I need some help with sizing the components and general circuit layout.
Thanks in advance for any help you may can give.
RE: Switch light on/off using a transistor based on input voltage range?
Cheers,
Benta.
"..the more, the merrier" Genghis Khan
But to measure both too low and too high, you would probably need an op amp window comparator circuit.
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
Thanks for everyone's ideas and help!
Cheers,
Benta
