Controllogix Ethernet
I've been having a problem connecting to our network on occasion and I'm sure it's a Window 2000 network setting. At times I can't connect to the PLC, with no response pinging. I can make it work by connecting to the internet, pinging to confirm, then returning to the PLC network. At times it will take a bit longer as the connection appears to be negotiating.
Anyone experienced this and what is the quick solution?
RE: Controllogix Ethernet
