Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The forum looks great! You guys have done a fantastic job on arranging things there...Your site is very precise and fun to visit..."
Geography
BridgeEI (Structural)
12 Nov 10 16:44
Has anyone ever seen/heard of a composite steel truss?  To clarify, I mean that the stringers/floorbeams would be composite w/ a concrete deck that is placed on top.  I'm wondering if this has ever been done.
bridgebuster (Civil)
12 Nov 10 19:49
We've done it - with at least with stringers. Although most of the trusses I've worked on did not make the stringers composite for various reasons. Waaaaaaaay back we had a client that was opposed to all composite design. In another case the panel lengths weren't that long that studs would make a difference.
As far as floor beams go, I think it's more economical and easier for erection to run the stringers over the floorbeams.
Qshake (Structural)
12 Nov 10 20:06
Yes, composite trusses have been in use since the 1960s especially for deck trusses.
As to high trusses, this has little effect on the overall truss behavior.
Pony trusses and deck trusses this is probably very helpful.
Qshake
pipe
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
graybeach (Structural)
16 Nov 10 8:25
I've done it for a thru truss.  We had I shaped bottom chords and made them composite with the concrete deck as well which eliminated the out-of-plane floor beam bending issue.
16 Nov 10 15:22
Thanks all for the input.  I just received a set of plans that has exactly what I was asking about as well.  The concept seemed practical, I had just never seen one before.  Also, was composite design being used that far back for trusses?  A lot of span bridges built around that time around here weren't designed to be composite.  It probably depends on which region one is in but we seem to be behind everyone.
hokie66 (Structural)
16 Nov 10 16:46
Composite decks make sense structurally...but I wouldn't use that system in cold areas where lots of salt is used.  Replacing a deck is one thing, replacing a composite deck is another.
Close Box
Join Eng-Tips® Today!
Join Us             Close
