Equipment selection
Equipment selection
Hello all
When we select equipment, always the available value dose not match the load calculations,
sensible load could be in range, but latent load is not, or visa-versa.
the sensible load would be ok in range of up to 5 or 6% less than calculated, but waht about the recomended range of the latent load
RE: Equipment selection
If the sensible is met, but the latent is insufficient, you probably need to be looking at more coils rows, preconditioning your OA or some other similar measure.
Machines rarely send E-mails and complaints about being uncomfortable, but let the humidity creep up on an office of old ladies and your phone will be ringging off the hook!
