Effect of chlorine in polymer effectiveness
We are using a ballasted clarification process in which we use chlorinated surface water (using chlorine gas) so the residual chlorine just upstream the clarifier is around 3 ppm.
The issue I want help on is if there's any experience that shows this "high" residual chlorine can affect the effectiveness of the polymer I'm using.
Any idea is appreciated
RE: Effect of chlorine in polymer effectiveness
Why don't you do a simple test by shutting off the chlorine and measuring the results?
