Reading Watermain Designs
Could someone please tell me what H and F stand for in these watermain design specifications?
Gate Valve 300FxH
22.5 Bend 300dia. HxH
End Cap 150H
Also, what does "Mech CPLG 150" stand for?
RE: Reading Watermain Designs
hub
flange
mechanical coupling
I think it's as follows, F= Flange, H=hub; Mech CPLG 150= mechanical coupling; I'm not sure about the 150.
150 is class 150
H typically means Hub. H is a term that is normally used with PVC fittings.
http://www.charlottepipe.com/Products/Assets/02C-PVC_List_Price/P-1109-TW.pdf
Gate Valve 300FxH probably means a valve with a flange end on one side and mechanical joint on the other end. Probably should be FxMJ.
Mech CPLG 150 is probably a mechanical joint coupling rated for 150 psi.
Thanks for your thoughts on these abbreviations.
I've got another question about joint flexibility, but I'll put it in a new thread.
Argghh -- might not be a bad idea if at least infrequently used acronyms were upfront provided with some standard or other (like key or glossary) reference, or similar in the documents in which they are used.  [See current discussion also of unknown acronyms at  http://eng-tips.com/viewthread.cfm?qid=201665 -- you are not the Lone Ranger!]
