Stiffness of PCB
Stiffness of PCB
I tried this in the materials forum, but since this is related to calculating natural frequencies I hope to get better responses here.
What is the Youngs modulus of a PCB (Printed Circuit Board). I have always assumed the the PCB is made from several layers 0/90 oriented layers of Continious Glass Fibre Plastic, and that no layers are oriented in 45 deg or any other directions. I need this to verify natural frequency of the PCB.
Thanks in advance
Thanks in advance
RE: Stiffness of PCB
Tobalcane
"If you avoid failure, you also avoid success."
Tobalcane
