Logo - table in drawing
Hi
I am new to Wildfire and I trying to create some formats for the company I work for. I have made a table and want to add their logo to the table.
I have tried to use insert object tool, with out luck.
How can I add their logo, which is format is jpg.
Thanks.
Kim
Thanks.
Kim
RE: Logo - table in drawing
Ben Loosli
I want the logo to be fixed inside a cell in the table. How can this be done?
Ben Loosli
I like to make a symbol of my logos though so I can easily pull them from my symbols location.
When I insert the logo (jpg file) through insert object function I only get the filename showing.
Why and how can this be changed?
You need to import the image into a blank drawing and then trace as a sketch the outline and save it as a sketch and then you can scale these sketched entities as needed to fit the area your looking to place it at. If you are having trouble with this I would be glad to do it as a bid job and then you can scale it to size. I am working in WF4 and the WF5 would be able to open this sketch.
Norb
Norbert www.linked in.com/pro file?viewP rofile=&am p;key=2315 1971&t rk=tab_pro
www.gdt-llc.com
http://
If it is a company logo, chances are it was originally drawn as a vector image, so rather than tracing it, just get your hands on the original file. Programs like Adobe Illustrator can save vector images as dwg files which you can then open in Pro/E.
-AAFuni
www.gdt-llc.com
http://
