Underpinning and Grade Beam Design
I have a structure with a below grade basement all supported on spread footings. Due to soil expansion we wish to underpin the structure with helical anchors and hydrovac soils from below the footer and install void form below the footer. We are esentially turning a reinforced concrete basement wall and footing into a caisson and grade beam system. My question is, how far can we space the helicals?
The factored gravity loads are minimal, less than 2KLF, the helicals are capable of 35kips. It seems to me my limiting factor is the capacity of my reinforced concrete basement wall that I am turning into a grade beam. How do you analyze this wall? Do I analyze it as a deep beam? I've only got #4 horizontal and vertical at 24" o.c .. I've got no horizontal steel in my footer.
Can I just analyze it as a normal beam? The helical guys suggest prescriptive spacing but it makes me nervous having never done this before.
RE: Underpinning and Grade Beam Design
