Plastics suitable for -40C applications
I'm looking for recommendations on plastics suitable for function at a temperature range down to -40C. This will essentially be a block, its sole functional requirement will be a compressive load, so I need something that doesn't become brittle at -40C. The resin must be injection moldable. I'm currently investigating glass filled nylon. What are good cold temperature resins?
Thank you in advance.
RE: Plastics suitable for -40C applications
http
http://www.tstar.com/materialsearch/default.aspx
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
LLDPE is good for -70°C, but not much else.
H
www.tynevalleyplastics.co.uk
Nylons are not good that cold but impact modifiers help. I would need to check the state of the art with nylons down that low. One problem is the cold air drys them out and nylon impact strength is very dependant on water absorption.
Polyester block co-polymers like Hytrel and Arnitel are very good at -40C but are quite expensive.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
I've looked at rulon, xenoy 6370, and I'll check out LLDPE next. Anyone actually spec a resin in a product for these application temps? Airplanes come to mind (ignoring thermosets).
Pat
for site rules
The CAMPUS database may be better for you than matweb although I do use MATWEB too.
Plenty of plastics are used at low temperature like Pat said in ski equipment and much more.
Further discussion with some tech reps has led me to be more comfortable using unfilled nylon 6/6 at these temperatures. The rep cited some GM applications as well as military.
We make military parts from ST801 and an EMS Chemie equivalent AZ3: http
H
Many automotive parts have to work at -40C.
Pat
for site rules
