Applicable Building and Design Codes for South Africa
I'm in the process of preparing the technical annex for an EPC contract to build a mill/plant in South Africa. Can some who has worked on projects in SA before advise which codes are typically used. I'm aware that SA has their own standards regulated by the South African Bureau of Standards but that is about all. I also assume they would generally rely on American steel and concrete codes and likely the UBC code but would appreciate some input to confirm.
Charles
Charles
RE: Applicable Building and Design Codes for South Africa
Start at the ECSA (Engineering Council of South Africa), the SA Institute of Steel Construction and the Cement and Concrete Institute.
Thanks just the same for offering to help.
