Material stiffness of PCB
What is the Youngs modulus of a PCB. I have always assumed the the PCB is made from several layers 0/90 oriented layers of Continious Glass Fibre Plastic, and that no layers are oriented in 45 deg or any other directions. I need this to verify natural frequency of the PCB.
Thanks in advance
RE: Material stiffness of PCB
"I have always assumed the the PCB is made from several layers 0/90 oriented layers of Continious Glass Fibre Plastic, and that no layers are oriented in 45 deg or any other directions." What a strange statement! Surely you mean you have used a PolyChlorinatedBisphenol in said composite. You are going the need the exact formulation of that PCB.
Steinberg is a good reference
(vibration analysis of electronic equipment)
I use a value of about 3E10 Pa
Caution: the resonant frequency is strongly dependant on the constraints, e.g. sliding vs fix edges
Won't the PCB be fastened with screws or another way so that the natural frequency of the free material will become irrelevant?
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
Yes, sorry PCB=Printed Circuit Board. This is a dymnamics problem more than material, so may be I am in the wrong forum.
What I am really asking is: Does the PCB have twisting stiffness of any significance?
Yes, PCBs are very stiff.
Definitely wrong forum- You want electronics
