Deleting a "saved WCS" and/or choosing to put your WCS back there
I am working in NX6. This is probably simple, I saved a WCS location using "Save WCS". Since then Ive moved my WCS back to 0,0,0. Now I want to put it back to the saved location, how do I do that? Also when Im done I want to delete it, it shows up in my drawings. Thank you.
RE: Deleting a "saved WCS" and/or choosing to put your WCS back there
To orient your WCS to the saved one just go to
format > WCS > orient > select saved WCS
It will not HIGHLIGHT and let me delete it, nor can I go to "Orient" and chose it. Strange!
If you want to keep the saved WCS but not have it show up in your drawing, remove it from the reference set (you are using reference sets and the master model approach, yes?). Alternatively you can use layers to hide it in the drawing.
Anyways, with all that being said, I tried to using inferred as the type and it just will not pick it up, honestly I cant even click on it and delete it....
