Stainless steel 304 grade
I use stainless steel sheets/bars/pipes/tubes in various sophisticated areas especially in hospital theatres. Hence this has to be anti scratch and anti corrossive. Can any body help me to find some method to protect from corrossion. ALso i would like to know how to remove scratches from SS 304 grade.
RE: Stainless steel 304 grade
You have problem \that is classified as "Everything Depends".
In a hospital environment I would use 316/316L SS in lieu of 304/304L SS due to 316/316L SS being inherently better to an increase in corrosion resistance. Just remember that every SS cleaning and polishing job is different and normally requires a little experimentation.
Neither will offer better resistance to mechanical scratching.
You might want to look at the AK type coatings as the offer a scratch resistant epoxy surface.  To remove scratches look at the products from Micro-Mesh and Scotch-Bite remembering that both can take off any coating.
For a gentile cleaning the Simple Green product is very good.
I assume that you are using bright finish SS. A point to remember is that if you have a bushed pattern stainless you have to follow the original pattern.
After using either the Micro-Mesh or Scotch-Brite product a coating of Shelia Shine will do wonders, or it may work by itself.
http://www.akcoatings.com/
http://micro-surface.com/index.php?main_page=product_info&products_id=77
http://www.simplegreen.com/products_stainless_steel.php
http://www.scotch-brite.com/wps/portal/3M/en_US/Scotch-BriteBrand/Scotch-Brite/Products/Catalog/?PC_7_RJH9U52300V2E0I02BK7KM0GT3_nid=M4R46N0NW6gsXS53M
BM97GglV9GMJHM8GHbl&prodID=M4R46N0NW6gs&lang=en_US
http://www.sheilashineinc.com/index.html
