High tolerance ID pipe/tubing
I am looking for seamless stainless steel pipe/tubing that has the ID very tightly controlled (+/- 1-10 thou or so on an ID of 1-2"). The other way to attain this is of course by reaming out standard pipe, but that's time and money. I'm hoping to at least take the time part out of the equation. Any suggestions, and where it can be obtained?
Thank you!
Thank you!
RE: High tolerance ID pipe/tubing
Depending on the material required short runs get very expensive.
Since your ID tolerance extremely thought have you though about ovality or straightness.
ht
http://www.tubularsteel.com/products_dometc.asp
http://www.scotindustries.com/tubing-products.php
Looks like they might make something in stainless.
h
Can you change your design to accommodate what's available?
All the DOM SS I've seen is in the large sizes and heavy wall. SS doesn't lend itself very well to the DOM process. Another thing is that the DOM process is not that accurate, this is why you see the honed version of DOM produced materials.
Here are two other sources that you maybe able to use if you don't need such tolerances.
http://www
http://www.tubemethods.com/sst.htm
http://www.astm.org/Standards/A1016.htm
http://www.plymouth.com/trent.aspx
http://www
