ASME-SA-312.358 pipe ID tolerance
Does anyone have the ID tolerance spec on 1-1/4" SCH 40 pipe?
Thank you!
RE: ASME-SA-312.358 pipe ID tolerance
Review A/SA 999, the information is there.
I don't have that either... was trying to get an answer without spending hundreds or thousands.
TeejT;
Well, I can send you a copy of the standard and my charge is $999.00 USD. Or, you can go to the web site below and order the publication
http://www.astm.org/Standards/A999.htm
for a whole $39.00 USD.
HAHA, thanks. :)
I'll take option B.
if you are manufacturong to code...........gotta have it
