NonManifold Add..
NonManifold Add..
Hello everybody;
I have a question about Nx7 Advanced Simulation.
I have several sheets (file attached) that intersect but don´t share any edge, and I want to unite them before I mesh to perform the simulation taking into account all sheets as a whole. I don´t know how do it. I´m looking for a buttom like "NonManifold add..." in FEMAP.
Any idea?
Any idea?
RE: NonManifold Add..
I would like to check it out, but I am on NX6.
I want to clear that I need to unite the sheets and generate a non-manifold geometry to mesh all as a whole. This will do my work more easy.
I attached the parasolid.
Thanks.
When sewing sheets together the edges must meet.
I think you may be able to figure out what I did by looking at the model.
Maybe step thru the model using: edit > feature > playback
I attached a part of the real structure for you can see.
Thanks.
I will try to come up with somethng that may help you,
but I am anxious to see if anybody can give their two cents worth.
