CATIA V5 Assemby/Installation Drafting
I have to make some CATIA V5 Drafting VIEWs of an airframe Installation.
I have to show in Installation VIEWs to some ASSYs only for reference (PHANTOM LINE TYPE - not included in Bill Of Material).
Can someone help me to find the best why to do this?.
In V4 I add the ASSY in the V4-SESSION and than I project the geometry in the VIEWs (SPC to DRW or SPC2 to DRAW commands).
I don't know if there is something similar for V5 system.
Thanks for attention.
RE: CATIA V5 Assemby/Installation Drafting
The CORRECT version is:
"I have to show in Installation VIEWs some ASSYs only for reference (PHANTOM LINE TYPE - not included in Bill Of Material)."
Thanks.
If I have understood you incorrectly, then try to compose your question more clearly.
Right click on "Front View"
Select "Front View Object"
Select "Overload properties"
Select the desired details in the view, they will show up in the menu window. You can then hide them, change line style, weight, etc.
When this command is used, you do not have to lock view, and, if the view get updated, it maintains the settings.
Harold G. Morgan
CATIA, QA, CNC & CMM Programmer
