NX6 Assembly Constriants - Infer Center Axis
Background:
Working in  NX6.0.5.3 MP3
Our previous part fams were built on mating conditions.  I am new to the role and was asked to lead up the NX6 implementaiton to our site(serves app. 400 daily NX users). NX6 was deployed sucessfuly and we have been using it since June.  I am now trying to capture items that slipped through as well as plan for the future with what I saw at the regional PLM conference.
I applaud the Reuse library and have been working as one of my main goals to populate this with everything that I can think of based off of our site standards and commonly used items. But in the conversion of our part fams, I am having an issue updating some of the assy constraints.
Questions:
1)When using a simple item such as a NAS623 screw(Touch and Align constraint), is there a way to force the remembrance of the axial geometry "Infer Center/Axis" during installation so that users do not have to select the dropdown each time or get the component placed tangent to the hole and not completely aligned?
2)Since I could not get this easily working through multiple attempts, I tried to use the concentric and touch align constraints when rebuilding my part fams.  At this point, when both constraints are present, it says that I am overconstrianed. Below are my information windows on the constraints.  Am I not properly understanding how the concentric constriant should function with others or do I have an issue with my model that does not allow me to select the cylindrical face of the shank of the fastener?
Concentric Constriant Information
Default Name         Touch (NAS623, KDW-ASSY_CONSTRIANTS/-)
Constraint type      Touch
Alignment type       Contra Align
Expression           None
Suppressed           False
Status               Over constrained
Reference 1          NAS623
                     Geometry name MATING.MATE1
                     Geometry type Face
                     Solved as Plane
Reference 2          KDW-ASSY_CONSTRIANTS/-
                     Geometry type Face
                     Solved as Plane
Owning part          KDW-ASSY_CONSTRIANTS/-
Layer                1
Type                 Assembly Constraint
Color                186 (Red)
Font                 SOLID
Width                Thin
Modified Version     19    05 Nov 2010 10:23 (by user wileykd)
Created Version      19    05 Nov 2010 10:23 (by user wileykd)
Touch Constraint Information
Expression           None
Suppressed           False
Reference 1          NAS623
                     Geometry type Face
                     Solved as Plane
                     Geometry type Face
                     Solved as Plane
@JohnBaker
I enjoyed and learned some cool stuff about NX7.5 at the recent Houston conference that I want to implement here, but its just me pushing the envelope right now!(with little to no money inside of course) :)
Thanks all
Kenny
RE: NX6 Assembly Constriants - Infer Center Axis
Kenny,
Are you saying that using Remembered Constraints doesn't work ?
NX 6.0.5.3
Windows XP32
Remembering constraints works, but the axial geometry isn't "keeping".  It always defaults to "Use Geometry" when I want it to stay as "infer center/axis" for my Align constriant.
If using Concentric, just select a circular edge on each part. It then makes the edges concentric AND co-planar.
NX 6.0.5.3
Windows XP32
