Why Reactor named as Reactor?
Reactor is an inductive device then why it is called a Reactor?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Why Reactor named as Reactor?
Why, then, isn't a capacitor also called a reactor? Because it was named after its ability to store (its capacity) electric charge. Nomenclature isn't always symmetrical or logical. It has evolved for a couple of hundred years and is not very consistent across different languages.
For example, a reactor is called a 'self' in French. The French borrowed the English words 'Self Inductance' and skipped the last part. There are loads of other examples in loads of other languages.
Gunnar Englund
www.gke.org
reactance => reactor
maybe..
Rafiq Bulsara
http://www.srengineersct.com
Gunnar Englund
www.gke.org
Inductive reactance opposes a change in current.
Capacitive reactance opposes a change in voltage.
With AC, the voltage and current are continually changing and as a result, reactance causes a phase shift.
Although reactance may be inductive or capacitive, the term reactor generally refers to an inductive device.
Bill
"Why not the best?"
Jimmy Carter
For another monkey wrench, I've also seen the value of reactors specified in KVAR. Capacitors are sometimes specified by KVAR
Neil
