Synchronized generator with different nominal voltage
Hi All,
Our existing generators are 11,000 V +/-5% output voltage. We set AVR 3% above nominal volt (11,350). Gens are running with voltage control set.
What do you think If a new gen 10,500 V +/-5% will be synchronized with existing system. It should run 8% over its nom volt.
Sumadi
Sumadi
RE: Synchronized generator with different nominal voltage
Gunnar Englund
www.gke.org
I don't know if your generator can do that, but check with generator manufactor.
