Material grade (Stainless steel) distinguishing problem!
We are having corrosion problem with some bolts that are supposed to be stainless steel(A2), when we sent a sample to a chemical analyses agent , we have got a chemical composition report differ from BS EN ISO for grade A2(Austenitic). Now, when some elements(C, Cr,Ni, etc..) abundance are differ between ISO standard and the actual chemical composition, what we would do? Are there some elements we only have to look at or all elements abundance have to be as per standards? In order to take decision whether this material or that are comply to standards or not.
Thank you..
Thank you..
RE: Material grade (Stainless steel) distinguishing problem!
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Hope this helps.
If the former, you probably have a chloride-ion problem. If the latter, you probably have bolts which have non-stainless steel imbedded in them from processing.
In the latter case, passivating should eliminate the problem.
