Tesla coil not working
Hi All,
Long time reader, first time poster. I'm currently building a tesla coil. here are the details:
1.) I'm using three parallel NSTs that each output about 6500 volts at .9 amps.
2.) I'm using 4 high voltage capacitors that I built using two sheets of aluminum siding with polypropylene as a dielectric between them. They are held together with a PVC ring, and submerged in mineral oil inside a 4" pvc tube. There are 4 of these.
3.) my spark gap is made from tungsten carbide held by mig welding tips (copper) threaded onto 6 gauge copper wire.
4.) my primary coild and secondary coil are in good shape, and for a topload I have a sphere and a tauroid.
I haven't been able to get it to work. When I connect the NSTs to the spark gap, it fires fine. but with I hook up the capacitor bank and the primary coil to the spark gap, the gap doesn't fire and there is no discharge. who can help me troubleshoot this? I would be most appreciative!
RE: Tesla coil not working
What's you primary like?
What happens with just the caps and the gap?
Keith Cress
Dan - Owner
http://www.Hi-TecDesigns.com
The primary is raised such that each turn of the coil is about a half inch above the last turn.
I haven't tried hooking up just the caps to the spark gap. Should the spark gap fire if I do that?
In response to macguyver, as of this week I'm officially in the tesla coil sector. The pay isn't great but it's fun so far :)
I'll try that later today and let you know how it goes. I'll also upload some photos.
I always suspect the homemade caps. Lots to go wrong with them.
Keith Cress
Bill
"Why not the best?"
Jimmy Carter
My Tesla coil terrorized the Science Fair judges as the primary arc was deafening and very intimidating. Alas I only got second place because the judges refused to believe I hand wound the thousands of turns on the 5 foot tall secondary.
Keith Cress
Keith Cress
Mike Halloran
Pembroke Pines, FL, USA
