Antis on struts
Antis on struts
Antis on struts
Can anti-dive/squat be measured on McPherson Strut suspensions? Is the force vector drawn the same as it is when finding the roll center?
RE: Antis on struts
Can it be /measured/ ? Sure
Can it be estimated from the geometry - yes. The SVIC is at the point where the normal to the strut at the body, hits the hinge line of the lower arms.
Milliken RCVD P633
Now whether that actually tells you anything accurate about weight transfer is another matter, I suspect that for a given car small changes in the kinematic anti will lead to the expected changes in weight transfer, but I'm not so convinced that you can really ignore the many secondary effects if comparing different cars. Having said that I've never worked in anger on a MacPherson strut for this stuff.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
RE: Antis on struts
So does this mean that changing caster can also change antis?
