running abaqus keywords in CAE
Hi All,
is there a way to run input files command by command in ABAQUS/CAE and make sure that the code i write using ABAQUS keywords actually work as expected?
if it's not possible in CAE, then whats the best way?
RE: running abaqus keywords in CAE
I've never done this in AbAQUS CAE, I usually call ABAQUS in a CMD.EXE window and then follow the solvers in PROCESS of TASK MANAGER and in the .dat, .log and .msg files opened in CONTEXT TEXT EDITOR or NOTEPAD.
Hope this can help you, best regards,
Eduardo
If I remember correctly, you can simply create new job in abaqus/cae and instead of model you can mark inp file (dropdown list model/input).
regards
Tomek
