What is the definition of RETAINERS according ASME IX
Can you give me the definition of the word RETAINERS according code ASME IX
What are the difference between the word RETAINERS with the word BACKING
Thanks you for your help
Dominique5058
Dominique5058
RE: What is the definition of RETAINERS according ASME IX
Backing is where welding is performed against either existing weld metal or a fusible material.
A learning curve is needed using either one. Neither can be used as crutch during a weld job, they are used to make a sound weld.
http://www.robvon.com/
http://www.cerbaco.com/index.html
If i understand your responses, the retainers is also a non-consummable backing
You agree ?
