voltage regulator problem
Hi all,
I am trying to use a fixed 2.7V voltage regulator (MIC5219-2.7YM5), and the voltage output is 1.4V when I wire it according to the datasheet and supply it with anywhere from 2.5V to more than 5V. When I tried putting a load on it (20K), the voltage drops to almost zero. Any idea why this is? I ordered three of these regulators and got the same result when I tried all of them. Thank you.
RE: voltage regulator problem
What is the input voltage to the regulator when you load it up?
Gunnar Englund
www.gke.org
Did you see any wild HF oscillation on the output?
Gunnar Englund
www.gke.org
TTFN
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
Everyone here has at some stage or other in their career, learned a similar lesson.
TTFN
