Connect Acuvim L series power meter using modbus to a pc
I was given a Acuvim L series power meter. Was ask to install the unit on a switchgear to monitor power. That part is done. Now I have been ask to connect the unit to a PC. Found it requires modbus RTU. There is a 3 terminal connector to connect to the unit. I beleive I would need a serial adapter to  connect the other end to my computer. After that I'm lost I know nothing about Modbus other than its a form of communication. If anyone knows where I can find help or done this before please let me know. Acuvim is no help.
Thanks TPMC
RE: Connect Acuvim L series power meter using modbus to a pc
You need an RS-232 to RS-485 converter. Modbus RTU on that device uses RS-485 communications. There are details of the data registers in the manual: http://eltime.rightwebdesign.com/resources/product/manual_65.pdf
Scotty
 So is ther special software for modbus?  Or is there something that has to be done on an exsisting computer other than connecting the Acuvim L meter to the RS-232 to RS-485 converter then connecting it to the computer. I will probably look to my IS dept for support.
Tpmc
Your meter usually would be connected to an RTU.  RTU's typically communicate via RS-485, PC's typically communicate via RS-232.  Hence the need for the converter.
Your PC needs software to display the meter data, it's not really related to modbus.
I note that the Accuenergy website offers both software and a RS-485 to USB converter.  Should be all you need.
I've had good luck with B&B Electronics converters. The 485USBTB-2W unit works well for USB to 2-wire RS-485. The port on the meter is supposed to be isolated so you should not need an isolated converter on the PC end.
There is a software package for the meter. If you don't like the look or functionality then you likely have to find a package you can customize or roll your own.
Robust Datacomm has some decent RS-485 notes here;
http://www.robustdc.com/application-notes/
Guys,
 I certainly appreciate the info provided. It is helpfull. I plan on attacking this project first of next week after hopefully finishing up a couple projects. I did find the software from Accuenergy website. I'll let you know what I accomplish.
Thanks again.
TPMC
