CAM Thread Operation Error 1770002 Help Please
Hello All,
I'm using NX 7.5. Windows 32 bit OS XP-Pro I had everything running smoothly, and then I had to add a V-thread to an external diameter of the journal I was working on.
So I added the generation and the simulated path work fine, and the moves list looks good, but when I post process I get:
Error: 1770002
Filename: o:/ugnx751\ip5\src\camsmom\no\ind
mom_td_definitions.c, line number: 503
Error Message: Error recived in do_event. Event Handler: C;\Program Files\UGS\NX 7.5\mach\resource\postprocessor\MS_NL1500Y_turn_master_in.td, Even name: MOM_lathe_thread_move, See
then it just trails off. I'm not sure what to do here. Is there a download to fix UG or does the post need to be altered?
Error: 1770002
RE: CAM Thread Operation Error 1770002 Help Please
I've now read the log for the error, but I'm no closer to knowing what to do.
Any thoughts?
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.1.5
Anthony Galante
if {$force_G76_block_once == "0"}
to: MOM_output_literal {$force_G76_block_once == "0"}
I'm attaching the resulting file, maybe someone better with Posts than me (admittedly I'm not very good) could lend me a hand
If that's the case you need to call the variable at the start if the block.
The error in log is as below:
can't read "force_G92_block_once": no such variable
while executing
"if {$force_G92_block_once == "0"} {
set force_G92_block_once "1"
MOM_force once G X Z F
My guess to fix is to add the following lines to the start of the block
global force_G92_block_once
set force_G92_block_once 0
Anthony Galante
I didn't mean to leave you hanging, but I think I got it working.
I didn't try it your way, but as long as it is working I will be happy to share.
What was odd though was all afternoon I've been getting error files that look like this...
I think my post builder is somehow corrupt.
Thanks everyone for all your help!!! :D
PB_CMD_thread_check custom command from the Rapid Move event
PB_CMD_thread_output custom command from the Lathe Thread event
and an "F" word in the Lathe Thread Event. If anyone needs the post let me know
