Ring Crane grounding
Are there any standards for grounding of a ring crane?
We were installing a ground loop with three ground rods and bonding the tracks together. Will this be sufficient?
Ernie K
Ernie K
RE: Ring Crane grounding
If this crane is running on rails you may consider grounding the rails every 50 feet or so. This would be with grounding electrodes and or bare cables, not an insulated grounding conductor from remote electrodes.
Bill
"Why not the best?"
Jimmy Carter
