Can't Select All Sketch Entities
Hi Everyone,
I created a sketch on a datum plan & used the rectangular feature & fully contrained the sketch.
After exiting out of sketch & using the Extrude feature, some of my curve entities are not selectable, even after use filters such as single curve, connected or tangent.
What would cause some sketch curve entities to not be selectable for a relatively simple command? More importantly, how can I get my extrusion?
Jason M.
Unigraphics NX Designer
RE: Can't Select All Sketch Entities
Jason M.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
As far as I can tell & should be, all curves are on the same plan - In most instances, on a datum plan. None of the curve entities that I'm trying to extrude are references curves either.
My cue line says my sketch is fully constrained, which it appears to be. However, for whatever reasons, I cannot select some of the (solid) sketch curve entities. With other sketches, within the same CAD file, I have virtually the same thing & have no problem getting a solid from the extrude feature.
I even selected sketch curves entities in different order & that didn't seem to help either.
Any other reasons that would cause this or how I can get this fixed?
Jason M.
Preferences -> Grid and Work Plane...
...and checking the options in the 'Objects Off Work Plane' section of the dialog.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thus far, the above suggestions are not working.
Just to test or to see if I can duplicate thei issue, I put a sketch on a datum plan & made a rectangle, using the internal sketch rectangle feature & let the auto constraints provide some constraints. I then exit out of sketcher, used the Extrude feature & made a rectangular solid, as it should.
Then, I went into sketch edit mode, applied some simple dimensional & geometric constraints & made a "fully contrained sketch".
When exiting, my 2 vertical sketch lines were no longer part of my extrusion string. I also attempted to add them back in, but I cannot select, no matter which option I choose.
What the heck is going on with NX 7.5 or this issue?
Any suggestions to how to get fixed (quickly)? It appears that I need to contact GTAC to.
Jason M.
If it is a bug then it really needs to get fixed.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I submitted my file to GTAC for review. This may be file specific issue, but I did have some other instances where I had the same situation. However, at the momenent, I can't duplicate the issue.
As for NX 7.5.2.5, I need it today if this the solution to my issue.
Jason M.
My problem is resolved!!!
It appears that I had my modeling tolerance too high & by going to:
Prefernece --> Modeling, General tab, change the Distance Tolarenace from 0,0254 to 0,010.
Jason M.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I was creating a .020 x 1 rectangle. Apparently, having 0.0254 model tolerance was a little too high.
Jason M.
John R. Baker, P.E.
Industry Sector
Cypress, CA
