MSE Wall - LRFD Version
In the external design of MSE structures, a limiting eccentricity of L/6 is conventionally used in ASD method. [Reference: Page 92, MSE Walls and Reinforced Slopes Design and Construction Guidelines, March 2001 (FHWA-NHI-00-043)] As we know, the limiting value is derived from the 'middle third rule'.
A latest version of this design manual was published in November 2009 with LRFD procedures (FHWA-NHI-10-024). This manual calls for a limiting eccentricity of L/4 (Page 4-23). Can someone explain the rationale behind this change?
The only reason I can think of is that in the ASD method eccentricity was determined before applying any factors. But in the LRFD method it is determined after load and resistance factors are applied. Is this the reason why limiting eccentricity is "relaxed"?
Thanks.
Thanks.
RE: MSE Wall - LRFD Version
