restoring command line?
Easy, but has me stumped this morning. With 2k how do I redock command line. It has disappeared and I can't seem to find it.
RE: restoring command line?
Hope that helps
Pea$e
I have done that. I have pretty much done an exhaustive search of the menus.
The problem precedes that solution. Adjusting the display is assuming that the command line is already present.
I have to find a way to prompt the program to display the command line.
I appreciate your help. This is a small, seemingly simple problem that is really aggravating me.
Thanks!
hope that helps
Pea$e
