How to perform boolean operation
I have two parts(3D) a cube and a cylinder. The cylinder is inside the cube. Some part of the cylinder comes out of the cube. I want to get rid of the part of cylinder coming out of the cube. The two parts represents composite and should be merged together. If I merge and then take off the part of cylinder coming out of the cube and then suppress the feature and then again resume it in assembly I get the original assembly with the cylinder still coming out of the cube. How do I get rid of the part of cylinder coming out of cube forever?
Thank you.
Thank you.
RE: How to perform boolean operation
Rob Stupplebeen
Thank you.
Rob Stupplebeen
