Heavy duty grating deflection formula
Does anyone know how the formula come from?
I checked into the Manufacturer's Catalog and found out the deflection equation is
D = P*[(2L^3)-(a^2*L)+(a^3/4)]/96EI.
Where
P=load per bearing bar
L=Clear Span
a=Partial Load contact parallel to span
Considering AASHTO H-20 vehicular load.
Many thanks.
RE: Heavy duty grating deflection formula
How many spans?
Michael.
Timing has a lot to do with the outcome of a rain dance.
It's single span. Thank you.
For a simple span, that is the formula for the deflection of a partially loaded beam when the load is in the middle.
Michael.
